c2 rocker arms rubbing valve cover - NCRS Discussion Boards
  • Brian K.
    • September 19, 2007
    • 174
    On my 327/300 a few of the push rod end of the rockers rub on the side of the valve cover slightly. I can see no appreciable wear on the studs. Is there such a thing as an oversize rocker? Has anyone else seen this?
    Thank you,
    Brian
    66 Coupe
    66 Convertible
    2022 2LT Coupe
    67 Chevelle SS396
    67 XLCH HD Sportster
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: c2 rocker arms rubbing valve cover
    do you have the covers on upside down????
    • William C.
      • May 31, 1975
      • 6037
      Look closely and you may find the covers are installed upside down, the 327 metal covers are not symetrical in shape as I relall.
      Bill Clupper #618
      • Loren L.
        • April 30, 1976
        • 4104
        Check for studs that are coming out *NM*
        • Don H.
          • December 1, 1981
          • 1487
          Re: Check for studs that are coming out
          There is a small "o" stamped in the top side of the stamped steel valve cover. It is very suttle and can be easily missed. Don H.
          • Brian K.
            • 174
            I thought they may be on upsidedown but the clip for the temp wire is in the right place. I did however get these at a swap meet. Is it possible there is a wire clipe on the exhaust manifold side for any other model? They are the correct type valve covers.
            66 Coupe
            66 Convertible
            2022 2LT Coupe
            67 Chevelle SS396
            • Brian K.
              • 174
              Yes tho "O" is in the right place.
              66 Coupe
              66 Convertible
              2022 2LT Coupe
              67 Chevelle SS396
              • Tracy C.
                • July 31, 2003
                • 2739
                Brian,
                There are rockers out there that may be oversized. Some have 1.6 or 1.7 ratios instead of the stock 1.5 configuration. I'm not sure what the scope of geometrical changes would be for these, but it is possible to find anything if you didn't build up the engine yourself.
                tc
                • Rob A.
                  • December 1, 1991
                  • 2126
                  Brian,
                  In the event you find you do need to replace any of the rocker arm studs, there is a kit available to convert to screw-in studs, without removing the heads. Just in case you have to go that route...
                  • Brian K.
                    • 174
                    Thank you all for your help!
                    66 Coupe
                    66 Convertible
                    2022 2LT Coupe
                    67 Chevelle SS396
