c2 radio capacitor - NCRS Discussion Boards
c2 radio capacitor
  • John D.
    • January 1, 2004
    • 29
    c2 radio capacitor
    While checking the distributor on a '67 small block I recently purchased I noticed that the wire leading from the (-)coil to the radio capacitor was disconnected at the capacitor. I tried to solder it back but was unable to make it stick. I thought I would just order a new one from Long Island Corvette.
    When I first noticed this problem I wasn't sure what the capacitor was for. Upon doing a little research I found out it was indeed the radio capacitor. I also read something that indicated it should be connected to the (+) side of the coil. Mine was connected to the (-) side of the coil.
    My questions are:
    What side should it attach to?
    What does the capacitor do in regards to radio performance?
  • Peter L.
    • May 31, 1983
    • 1930
    Re: c2 radio capacitor
    John -
    Question #1 - Check the '67 Corvette AIM UPC U69, Sheet A5 and you'll note the illustration shows the small block capacitor connects to the + side of the coil.
    Question #2 - I doubt if you will notice any difference in radio performance. Except for judging most of us wouldn't bother or miss having them.
    Pete
