61 orginal motor - NCRS Discussion Boards
61 orginal motor
  • Don 42616
    61 orginal motor
    I was curious if this e bay C1 motor is orginal. Does the C1 series have Vin. stamped on motor pad to determine originality? thanks, Don
  • Mike M.
    • May 31, 1974
    • 8385
    Re: 61 orginal motor
    without seeing the pad, its impossible to determine if the 61 has its original engine.originally, the vin # was stamped on the pad, as well as the machine assembly data. base engine vettes usually have their original engines but get a knowledgable NCRS judge to examine it before forkin over 40K+. mike
    • Tracy C.
      • July 31, 2003
      • 2739
      Ask the seller for a high resolution close up
      of the stamp pad and then post or email it to Mikie #14. He has seen a lot of phony stamp jobs and can spot one in a New York minute.
      Anybody that's been around the hobby more than 6 months knows it takes more than a fancy eBay write-up to convince a knowledgable buyer the car has the "original" block.
      If the seller can't produce this for you, assume the engine is incorrect.
      good luck,
      tc
