Tachometer cable - NCRS Discussion Boards
Tachometer cable
  • John O.
    • May 31, 1998
    • 480
    Tachometer cable
    Hi guys
    I have another question. I just ran the speedometer cable to the speedometer through a hole in the firewall and through a hole in the fiberglass behind the gauge housing.Hooked up with no problem. Now i'm trying to run the tachometer cable to the tach.I'm not sure how to route the cable.I'm not getting much info from the assembly manual that I can see. Can someone tell me how it should be run. Does it also go through a hole behind the gauges housing? Also where the cable comes through the firewall from the distributor,is there supposed to be a boot on the cable to seal the hole?
    Thanks...John
  • Collin MacDonald
    Re: Tachometer cable
    You should have a rubber grommet in the hole in the firewall the cable passes through. You can purchase at Long Island of Corvette Central. It comes in a set with other firewall grommets.
    • John O.
      • May 31, 1998
      • 480
      Hi Collin
      According to the assembly manual,the cable goes through a large egg shaped hole right dehind the distributer.The book shows a rubber boot that covers that hole.The hole is large to allow room for the movement of the tach during timing procedure.I need to know the route of the cable under the dash.Does it go under, over or between the wiper cables? etc. etc. etc.
      Thanks..John
      • Mike E.
        • February 28, 1975
        • 5138
        John--
        I haven't committed to memory what year car you have. Routing is largely dependent on that.
        • John O.
          • May 31, 1998
          • 480
          Hi Mike
          I have a 1962 250 H.P. 4 speed
          Hopefully you'll have some info for me.
          Thanks..John
          • Mike E.
            • February 28, 1975
            • 5138
            John--
            Call me Saturday morning about 10AM on my cell phone 414 698 4126
