C1 Hood Weatherstrip - NCRS Discussion Boards
  • Peter Cipriani
    Does CC sell the correct hood ledge weather strip? The one I got from a kit in Carlisle has an odd shape a more acute angle of 75' with a step in the back. Hard to explain!! It does not look like the original rubber that I removed.
    • 43222
    Re: C1 Hood Weatherstrip
    Peter-----
    I do not know if CC has the correct weatherstrip for C1 applications. They very well may have it. However, I am fairly sure that the weatherstrip for the hood ledge application sold by Dr. Rebuild is very correct as to configuration and texture.
    • Mike M.
      • May 31, 1974
      • 8390
      no one, to my knowledge, repo's the 61-62 hood w/s that is exactly like the originals. if you have the original, i'd use it, unless the condition is deplorable. mike
      • John M.
        • January 1, 1999
        • 1553
        Peter,
        You did not state what year car, but if you are talking about the 59-60 front ledge weatherstrip that goes over the radiator to seal it to the hood, then Doc Rebuild makes a perfect repro. His matched the remnants of the original on my 60 to a "T".
        Regards, John McGraw
        • Peter Cipriani
          Re: 61 John! *NM*
