radio interference - NCRS Discussion Boards
radio interference
  • John Thomas
    radio interference
    I would appreciate recommendations on how to get rid of alternator noise in my radio. I "drive" a 67 small block coupe. I removed the original headers and installed tuned headers. Naturally, I can't re-install the ignition covers.
  • Bob R.
    • June 30, 2002
    • 1595
    Re: radio interference
    There are several things on the car that contribute to the noise supression of the radio. Are all the capacitors in and working properly. Are all the ground wires installed. With the headers you cannot install the side shields, are the lower shields and the top shield in place. If all these items are correct then I have no other suggestions.
    • John Thomas
      All the capacitors and ground straps are installed. The top shield and the shields from the top shield down to the location of the side shields are installed.
      • Mark Aye
        since you installed headers, I am guessing you have resistance wires and plugs. If you can put an hei ignition in as well, it will help. the wires and plugs should cure most of it.
        • Paul Reynolds
          Since you have headers and are not concerned about originality, maybe you could try some Big Block plug wires with the metal jacket and ground clips.
          • John Thomas
            That's a thought.
