Interior Trim - NCRS Discussion Boards
Interior Trim
  • Bill B.
    • June 30, 1999
    • 182
    Interior Trim
    The interior trim of my C2 coupe has numerous screws that will not longer stay in due to numerous times they have been removed and the holes are too big. The problem is in the rear halo surrond area and rear window trim. I am thinking of refilling the holes with resin before reinstallation. Is this the correct procedure or is there a better way. Thank you.
    Bill Bonnichsen
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Interior Trim
    I had the same problem installing my door panels. I thought about using resin but I didn't think it would be strong enough. I ended up using a liquid metal material. I filled the hole let it harden drilled a pilot hole and installed the panels. It worked very good.
      Re: Interior Trim
      Small tapered plastic drywall anchors also work very well for wallowed-out trim screw holes
