I'm Stuck On You - NCRS Discussion Boards
I'm Stuck On You
  • Bill Shepherd
    I'm Stuck On You
    or maybe I'm not...A previous owner put hood scoops on my Vette. One of the scoops is starting to come loose. What product , specifically, can I use to reattach this plastic (polyurethane, maybe ?) scoop to the fiberglass body so that it will look fine and last a long time ? Thanks for you suggestions.
  • Jerry
    Re: I'm Stuck On You
    Bill:
    The Vette Bond product a couple of posts above yours will probably work but if you will pardon the comment, it will never look "fine" and considering the opening and closing of a hood will not last a lifetime, consider buying a replacement hood, as even with the bonding, they will always be problematical.
    jerry
