Rear cover bolts - NCRS Discussion Boards
Rear cover bolts
  • Rob Matthes
    Rear cover bolts
    I am ready to reattach my rear cover on the differential. I have heard the bolts are cad/zinc coated. I have also heard that they are suppose to be black. Can someone verify the plating/color of these bolts? Also, any recommendations for the gasket. Should I use a silicone material or just bare?
    TIA, Rob 1967 327/350 hp
    • 43221
    Re: Rear cover bolts
    Rob----
    The bolts were black oxide or black phosphate; they were NOT plated. For a gasket I would use a stock GM gasket which has been very lightly coated with grease.
    • Rob Matthes
      Joe,
      Thanks for the info. Do you or does anyone know of a kit to do the black oxide or black phosphate on bolts?
      Rob 1967 327/350 hp
      • WayneC
        Try: http://www.eastwoodcompany.com
        • Jerry Clark
          There is also www,caswellplating.com , they offer a complete line of most all finishes and thier products are excellent.
          jerry
