'57 Transmission - NCRS Discussion Boards
'57 Transmission
  • FRED S. CRAPROTTA
    '57 Transmission
    Does anyone know where I can get some information about casting numbers for 57 transmissions? Joe Lucia gave me some good insight about my case a while back but I am still trying to get the correct number for an early '57 tail. I have three 56-62 tails and they are all different.
  • James F.
    • December 1, 1985
    • 596
    Re: '57 Transmission-Fred
    Fred, This is from memory, so beware. Early '57 3-speeds cast tail numbers ended with 450 and were not date coded. Later'57 tails were date coded. Regards
    • Theodore K.
      • December 1, 1985
      • 214
      Excellent 4 page article in Spring 88 restorer. The last page has a good chart on the number make up. IF you don't have access to one I can scan and email a PDF of it to you.
      Ted von Kampen
      • FRED S. CRAPROTTA
        I don't have that article. I would sure appreciate it if you would scan it and send file to fred@eclipsemold.com. Thanks a million Ted. Fred
