C1 steering column - NCRS Discussion Boards
C1 steering column
  • Pat #25912
    C1 steering column
    How far down on the steering column does the housing for the signal light switch go? Everything is freshly painted and I just know that housing is going to scratch the column as I slide it down. Thanks again. Pat G.
  • Mike M.
    • May 31, 1974
    • 8396
    Re: C1 steering column
    masking tape the col mast jacket, slide the turn signal housing down. its exact location will be determinable once you attach the steering wheel. shoot for about 1/8th inch gap between steering wheel hub and trun signal housing. good luck, mike
