c1 engine oil leak distributor - NCRS Discussion Boards
  • Sander B.
    • March 1, 2005
    • 499
    Hello all
    after driving about 1/2 hour there is some oil leaking on the intake manifold, leaking out of the distributor
    oil level is Ok
    what can it be ????
    Thanks Sander,
    Re: c1 engine oil leak distributor
    Is it leaking from where the base of the distributor meets the intake manifold surface? There's supposed to be a circular gasket under the flange on the distributor.
    • Sander B.
      • March 1, 2005
      • 499
      the gasket is there it seems its leaking from the base plate under the distributor cap first i thought it came from the oil presure line
      • Jean C.
        • June 30, 2003
        • 688
        Sander, just a thought, but if you have a leak in the oil pressure line or fitting at the block, it could possibly spray oil on the base of the distriutor making it appear that oil is leaking from the distributor.
        Best regards,
        Charlie
        • Joe R.
          • March 1, 2002
          • 1356
          Others have mentioned the distributer gasket and the oil pressure fitting as suspects. Another suspect is the rear seal on the intake manifold. I had a leak from that seal and it took a while to pin down the source. I had to clean the whole area squeaky clean, then run the engine at about 2000 RPM for several minutes while I watched the area continuously. Perhaps a similar approach would identify the specific source of your leak.
          • Don 42616
            Re: c1 engine oil leak Yes Intake manifold
            I had same oil leak Joe Randolph had in front. Indeed it was intake manifold leak.
