Tie rod ends - NCRS Discussion Boards
Tie rod ends
  • Steve D.
    • February 1, 2002
    • 990
    Tie rod ends
    Once the tie rod ends are threaded into the tie rod (one end right hand threads, one end left hand threads), does it make any difference which end goes into the steering knuckle and which end goes into the center link?
    Steve
    • 43203
    Re: Tie rod ends
    Steve----
    From a strictly functional perspective, it does not. The only thing that changes when the tie rods are "swapped end-for-end" is the direction that the sleeves (tubes) need to be turned to expand or contract. However, the tie rod assemblies were originally installed with the right hand thread ends at the OUTER position on BOTH sides.
    The outer tie rod ends were often marked with a daub of YELLOW inspection dye. The inner rod ends were often marked with a daub of BLUE inspection dye.
    • Mike M.
      • May 31, 1974
      • 8377
      Re: Tie rod ends
      no. mike
