C1 motor mount shims - NCRS Discussion Boards
  • Pat #25912
    The AIM mentions shims for the right side motor mount where it bolts to the frame rail. Are these special shims? Are they available anywhere? Thanks. Pat
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Pat, Have not worked on a car that had any...
    ...shims in place. Actually I believe the AIM calls for longer bolts on the RH side to accomodate such shims. As a guess, if there was an issue of too much gap, I'd probably head for the flat washer department. Does the AIM call out a part # for the shims that you can find somewhere else for some other application in the AIM ?
    • Chris H.
      • April 30, 1990
      • 817
      Re: C1 motor mount shims
      My '62 had no shims but I believe the engine was out at one time.
      I seem to recall a thread here that the shims were never used in production. Engineering had them released if the frame was outside of tolerances?
      chris
      • Chris H.
        • April 30, 1990
        • 817
        found this in the archives.
        chris
        • Allen W.
          • September 30, 2000
          • 106
          I have recently replaced the motor mounts on my 56. In completing the task I noted to line things up properly I needed some shims. My mounts were badly worn so I can't quite tell what kind of bind Bubba might have caused. I used regular front end alignment shims to make the adjustments.
          Allen
          • Pat #25912
            Thanks guys. Mine is only out by 1/8" from the AIM recommendation so I will probably leave it. I noticed the bolt hole on the pass side of the front cross mount is bigger than the hole on the drivers side, is there a reason for that?
            Thanks again. Pat
            • Dennis C.
              • January 1, 1984
              • 2409
              Yeah, It's for minor positioning adjustment... *NM*
