60 Wiring Routing - NCRS Discussion Boards
60 Wiring Routing
  • John M.
    • January 1, 1999
    • 1553
    60 Wiring Routing
    Can anyone help me with the routing of the wiring harness from the fuseblock to the dash? The AIM shows the harness running over to the door hinge area then under the brace to the backside of the dash but when routed in this manner the wires to the stoplamp switch are way short of reaching the switch. The only paths that look proper are to the inside of the emerg. brake and then under the brace and up to the clips at the windshield base or above the upper brace between the brace and the fiberglass of the cowl. The harness is a Lectric Ltd. repro but appears to be exactly the same as the original. All comments would be appreciated. TIA
  • Mark L.
    • January 1, 1996
    • 121
    Re: 60 Wiring Routing
    John, I'm hesitant to respond to this just working from memory, I have pictures from my '58 when I took it apart in '95, I'll look tonight. Anyway your post rings a bell with me I'm pretty sure the harness was inboard of the e-brake shaft. E-mail me off-line if you want to look at the pics.
