76 Carb Question - NCRS Discussion Boards
76 Carb Question
  • Christopher J. Bunsey
    76 Carb Question
    I broke out my car for the first time this year, and I noticed when I came home and was cleaning the carb, that the rear 2 barrels choke/butterfly were not open. The front two were. This is only the third time I have driven this car, and want to know if this is normal (the car seems to run fine) or if some thing is wrong. It ia a 1976 L-82 all stock w/ AC. Any insight would be appreciated.
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: 76 Carb Question
    Christopher,
    You probably have a Quadrajet carb. If so, what you see is normal. The secondary barrels (back two) are vaccumn operated and don't open until your engine rpm requires a fuel above what the primary's can provide.
    tc
