AC Delco spark plugs - NCRS Discussion Boards
  • lyndon sharpton
    Any one know about plugs that have a X after them. I have some R43TS then ran across some R43TSX what is the X for?
  • Joe C.
    • August 31, 1999
    • 4598
    Re: AC Delco spark plugs
    Wide gap for High Energy Ignition.
    • mike cobine
      The X is for a .060 factory gap. The standard TS is a .035 factory gap that can of course be changed. However, stretching it out to .060 is a bit extreme. The -X version is already there.
      There is also an -8 version that is a .080 gap.
      As usual, you should always check your gap as the factory gap may not be accurate at time of installation.
