1957 STEERING BOX/COLUMN - NCRS Discussion Boards
  • Michael Noguera
    1957 vette-
    What is the proper sequence for reinstalling the steering box when the body is off the frame?? Assuming the frame is complete with motor/transmission in place.
    I removed the steering box when the body was gutted but in place and the frame was bare. IT was quite a task even then.
    Thank you in advance,
    Mike # 35882
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Mike: Suggest you simply...
    ...put the steering column in the car BEFORE you set the body on. Just tape it or tie it in the appropriate location so it does not bang around during body drop. Best, Dennis
    • Mike M.
      • May 31, 1974
      • 8385
      Re: 1957 STEERING BOX/COLUMN
      with body divorced from frame (with engine installed), there's only one way. insert the assembled streering col thru firewall and thru dash and make a fixture to keep the col from damaging the firewall or dash. then drop body on frame.good luck, mike
      • Dennis C.
        • January 1, 1984
        • 2409
        Gee whiz, Mikie, what was I thinking with my...
        ...dumb answer about putting the column in prior to body drop. Having you answer questions that have already been answered may keep you in the "Top 25", but you'll never catch Joe Lucia. He actually knows stuff...
        • mike mccagh
          Re: Gee whiz, Mikie, what was I thinking with my..
          sorry i dumped on your response but it didn't pop up till after i'd typed my response. never did care much about being in the top 25 of anything and nobody will ever top joe till the ground hogs start delivering his mail. hope the 3 of us are around for another 25 years or so.mikie
          • Tracy C.
            • July 31, 2003
            • 2739
            well hey...if it took you 11 minutes to type that
            I guess my typing skills aren't as bad as I thought. (I could have done it in 10 minutes flat)
            maryland missle?.. come-on mikie, where's the beef!
