C2 '67 neg. batt cable - NCRS Discussion Boards
  • Tom Merkel
    Where should the negative battery cable terminate (ground) - on the frame below the battery tray, or at the rear (ground) part of the soleniod?
    This is for a non air '67 SB.
    (The AIM shows it terminating at the solenoid, yet mine runs to ground below the battery tray.)
    Also, could someone guess its length from battery to solenoid?
    Thanks for the help.
    Tom
  • William C.
    • May 31, 1975
    • 6037
    Re: C2 '67 neg. batt cable
    Actually what it is showing is it attaches to the outer bolt holding the starter to the block, along with the ground from the wiring harness. Item 3 on page A-6 of UPC 12 in the assembly manual.
    Bill Clupper #618
