C2 alignment question - NCRS Discussion Boards
  • Randy S.
    • January 1, 2003
    • 586
    I assume front end camber is adjusted with the Upper A Arm shims. Where is the adjustment for castor?
    Randy
  • Donald T.
    • September 30, 2002
    • 1319
    Re: C2 alignment question
    Castor is also adjusted with the upper A arm shims. Moving the shims from front to back, and vice versa will adjust the Castor.
    • Randy S.
      • January 1, 2003
      • 586
      Don,
      I think I see. Adding equal shims to front and back changes the camber but adding shims to the front OR back A Arm rotates the top a arm relative to the bottom a arm thus changing castor.
      Long Island Corvette catalog sheet 49 item 8 shows camber adjusting bolt. I can't seem to locate it on my 66 but it looks like it would be a "jacking" screw to facilitate adding shims.
      Randy
      • Dick W.
        • 10483
        Randy item #8 appears to be the upper "A" arm mounting bolts. The go through the frame into the upper inner shaft in the control arm
        Dick Whittington
