67 backup light switch mounting - NCRS Discussion Boards
  • Scott Marzahl
    What do the two screws/bolts that hold the B/U light switch supposed to look like, are they phillips machine screws or hex head screws?
    Thanks.
  • Terry F.
    • September 30, 1992
    • 2061
    Re: 67 backup light switch mounting
    I believe they are small hex heads. As I recall the heads were slightly recessed and were stamped with a letter or character. Been a while since I looked under there. Terry
    • Wayne M.
      • March 1, 1980
      • 6414
      Scott -- I'm looking at two switch/bracket/shield assy's I have; they both have the recessed hex head bolts/screws, as Terry mentions. Also both have star washers (captive, it appears). The switch from my late '65 has R_B_W at 120 degree spacing. The other (not sure of year) have a large "M" in the center, with a slightly taller "I" through the center of the "M".
      • Terry F.
        • 2061
        Both head designs are more than likely correct since GM sourced from more than one supplier for fasteners. Thanks, Terry
        • Scott Marzahl
          Thahnks for the help Wayne and Terry
          Thanks for the help Wayne and Terry, and good meeting you Wayne.
          Scott
          • Terry F.
            • 2061
            Re: Thahnks for the help Wayne and Terry
            I believe Paragon will have those screws.
            You are welcome, Terry
