C1 windsheild lower trim - NCRS Discussion Boards
  • Larry S.
    • August 31, 2000
    • 356
    I am building a 1962 vette and Last month I replaced the glass (well almost the chrome plater sent me back some one elses corners REAL LONG STORY) so tonight I installed the corners and I just cant figure out for the life of me what holds the lower stainless in place.
  • Ed Jennings
    Re: C1 windsheild lower trim
    It locks into the lower channel with the gasket. Needs to be installed befrore the glass is installed.
    • Larry S.
      • August 31, 2000
      • 356
      Ed when you say lower channel do you meen the channel on the car? Or do I have to disasemble the windsheild asembely?
      • Ed Jennings
        I'm refering to the steel channel that the glass, gasket, and molding all fit into. The bottom piece into which the T-bolts fit. Yes, I think you will have to disassemble the w/s. If you try to force the molding into the channel with everything else in place, there is a strong possibility of breaking something. Do you have the ST12? There are pretty good assembly directions there, and as I recall there is a cross section diagraqm of the lower channel.
        • Larry S.
          • August 31, 2000
          • 356
          I am not sure of what the st-12 is.
          I was able to get it all together with out cracking the glass.I will take it back apart and try Again
          • Ed Jennings
            The ST-12 is the factory service manual for C-1's. It is available from the NCRS bookstore, or any of the catalog vendors. Kind of a "must have" publication for C1 owners.
              Larry -
              The "ST-12" is the C1 Shop Manual, called "1953-1962 Corvette Servicing Guide" on the cover, with "ST-12" in the lower right corner; it's the only Shop Manual GM issued for C1's.
              • Larry P.
                • June 30, 1999
                • 481
                C1 windshield notes
                I made some notes when I did mine.
                LP
