Tire pressure - NCRS Discussion Boards
Tire pressure
  • Kevin M.
    • November 1, 2000
    • 1271
    Tire pressure
    A few weeks back there was a thread about tire pressure. I went out and looked at my Firestone radial repo redlines and there was no pressure listed anywhere on the tire. It said do not exceed 45psi when mounting but no other mention of pressure. It did tell you to refer to your owners manual. Well it says 20psi just like the sticker,of course this is my original manual. No one in the previous post had a recommendation other that check the tire. So I running standard repop redlines what should the pressure be?
    Kevin
    • 15657
    Re: Tire pressure
    32 psi (cold) all around for best handling, low rolling resistance, and minimum heat buildup in the tires.
    • Kevin M.
      • November 1, 2000
      • 1271
      Re: Tire pressure
      Thanks Duke.
      Kevin
