Horn - NCRS Discussion Boards
Horn
  • Dave C.
    • March 1, 2004
    • 82
    Horn
    Everytime I pull on my steeringwheel my horn goes off. Any Ideas on how to stop it without disconnecting the horn alltogether?
  • Dave C.
    • March 1, 2004
    • 82
    Re: Horn
    Forgot.....It's a 1966 bigblock
    • Donald T.
      • September 30, 2002
      • 1319
      Re: Horn
      Dave,
      Just disconnect the negative battery cable. You won't hear a thing!
      • Dave C.
        • March 1, 2004
        • 82
        Re: Horn
        Thanks, for the help
        • Wayne K.
          • December 1, 1999
          • 1030
          Re: Horn
          Dave,
          I think I know your problem. I had a horn issue too When I was turning the steering wheel to negotiate corners the horn would blow sometimes You need to pull the steering wheel. One of the things you"ll find under the hub is a vinyl or plastic disc. This disc can wear thin over time which can result in the horn blowing. You need to repair or replace the disc.
          Wayne
          • Dave C.
            • March 1, 2004
            • 82
            Re: Horn
            Thanks, Wayne....I just orderded it form Zip
