crankshaft 63 SHP - NCRS Discussion Boards
crankshaft 63 SHP
  • jim cear
    crankshaft 63 SHP
    My machinist says that the crank needs to be ground 20 under. Would I be better off/safer with a new replacement or is the regrind acceptable?
  • William C.
    • May 31, 1975
    • 6037
    Re: crankshaft 63 SHP
    There are several threads on this topic in the archives, bu the summary is for anything less that all-out racing, a properly done regrind is perfectly suitable.
    Bill Clupper #618
    • nancy charles
      by cutting the crank .020 under doesn't that weaken it by taking out the tough ride suffice ?
      • Dick W.
        • 10483
        Tufftriding I believe came about in the later 60's. A properly ground and radiused crank journal is durable enough for a street engine without any worry.
        Years ago, before the advent of all the aftermarket crankshafts, quite a few racing cranks were turned undersize to index the throws. Precision crank machining at the factories left something to be desired.
        Dick Whittington
        • nancy charles
          are you saying a 327/340 ( S.H.P. ) crank is the same as a 327/250 ( H.P. ) ?
          • Chris D.
            • November 1, 2002
            • 198
            Different part numbers were made from the same raw forging. 340 & 360 HP cranks were drilled and tapped for the harmonic damper bolt. I suspect they were balanced differently as the piston weights were different. Don't know about surface treatments.
            • William C.
              • May 31, 1975
              • 6037
              Yes, with the exception of balancing and turtriding process. The surface hardening is a nice touch for an engine being raced, but is not really necessary for a street engine, including one that sees an occasional burst of driver exuberance.
              Bill Clupper #618
                • 15686
                The first question I would ask is: Why does it need to be ground?
                All the journals on my 327/340 crank at 115K miles miced out right in the middle of the OE dimension range. I had it Magnafluxed (passed), checked for straightness (passed), and polished.
                These cranks ARE Tufftrided, and it is best not to grind them unless absolutely necessary, however, they will very likely survive in a restored engine, which is not likely to be run at high revs very often.
                There are various processes that can restore the surface hardening, but they are usually pretty expensive.
                • Dick W.
                  • 10483
                  I learned something. I thought that the tufftriding came into being about the time that the 302 engine was built.
                  Dick Whittington
                  • nancy charles
                    the 63 340&360 hp. cranks were ( 2680 STEEL )drilled snout for the ( 8" ) balancers .
