Re: I've used both and the winner is?????
BOTH!
Both Kroyl and PB work extreemly and equally well.
Kroyl boasts that it can also be used to lube air tools as well.
The advantage of PB Blaster is that you can get your hands on it over the counter at Lowes, Home Depot, Ace etc.
With Kroyl on the other hand, you will have to order it unless you have a lubricant distributor near by who either has it or can get their hands on it.
I would wave a torch around the fitting warming it up but not to the point of either bluing the fitting or discoloring it. A couple of sequenses and it will probably pop free.
You can also use a penetrant along with this process, but not untill the torch is turned off and the fitting has cooled off to the point where it is barely hot to the touch.
A cheap bottle torch can easily handle this task. Just be exteemly mindfull where you wave the torch and take adequate precautions.
Good luck Mike,
Chuck
BOTH!
Good luck Mike,
Chuck
