C3 - '71 350/270hp cam question - NCRS Discussion Boards
  • Jim Callan
    Would this engine have a 'cam button' ? I disassembled this engine and 'bagged and tagged' everything, and I don't have anything that looks like a 'button'. The rebuild manual says to "make sure the cam/thrust button is installed" before the timing cover is installed. What have I missed or lost ?
  • William C.
    • May 31, 1975
    • 6037
    Re: C3 - '71 350/270hp cam question
    Stock cam does not use the "thrust button" Many aftermarket Roller cams need it. The GM service manual does not mention it, you must be looking at a "hot Rod" rebuild guide.
    Bill Clupper #618
    • Jim Callan
      Thanks Bill - I'm using a haynes rebuild manual.
        Good reason to use the GM manuals instead; the Haynes/Chilton manuals are way too generic.
          • 43221
          Jim------
          The strange thing is that cam buttons were never used on ANY PRODUCTION or SERVICE GM small block or big block engine assembly. They are strictly an aftermarket-type item, although GMPP does sell them for certain "high performance" use.
          All GM PRODUCTION or SERVICE engine assemblies that use a roller camshaft requiring thrust control use a thrust plate that attaches to the block with 2 special screws. This system is FAR better than the thrust button approach, but it cannot be retrofitted to blocks not originally so-equipped. So, the cam button is used when aftermarket roller cams are used in blocks not originally using a roller cam.
          • Craig S.
            • June 30, 1997
            • 2471
            Haynes and Chilton are good door stops.......get the GM manual.....Craig
