springs - NCRS Discussion Boards
springs
  • Don 42616
    springs
    Does the springs in my 67 look like the need to be replaced? If not why don't thr arc? Thanks , Don Pic enclosed.
    I am still working trying to understand how to send multiple photos. Like the group Scott sent.
  • Rob A.
    • December 1, 1991
    • 2126
    Re: springs
    Don,
    Before considering replacing the spring, install new rubber cushiions. It's hard to tell from your photo how compressed they have become. I received that recommmendation here from Duke recently. I replaced mine, and gained about a full inch and one half ride height and the spring displayed more arc.
    • Rob A.
      • December 1, 1991
      • 2126
      Re: springs
      Don,
      Your spring looks just about like mine before I replaced the cushions, and I'm happy with it now. Duke's recommendation was excellent.
        • 15674
        It just needs new cushions! *NM*
        • Don 42616
          Re: It just needs new cushions!
          Duke, at risk of seeming dense where on my photo are the cushions. Don
            • 15674
            The four rubber spring link cushions - two on each side. Look at your photo.
            • Mark P.
              • July 31, 2003
              • 407
              How tough are they to replace?
              Mark Pugmire
              54 Pennant Blue
              56 Cascade Green Dual Quad
              56 Arctic Blue Dual Quad
              66 Nassau Blue 427 L36 Convertible
              67 Marlboro Maroon L79 Coupe
              • Randy S.
                • January 1, 2003
                • 586
                Don,
                The spring cushions are at each end of the bolt that connects the spring to the trailing arm. Like Rob, I also took Duke's suggestion to replace the spring cushions. Will restore ride height and improve handling . My mechanic also suggested replacing the bolts too. You can buy bolts, spring cushions and spring cusion retainers and washers all in one kit from GM about $50. Check archives for part number.
                Randy
                  • 11643
                  Mark,
                  I've replaced an entire rear spring in half an hour, so the rear end link cushions shouldn't be much different by themselves.
                  Patrick
