61 E-brake warning lite - NCRS Discussion Boards
  • Norman S.
    • September 30, 2002
    • 69
    My little red lite in the instument panel seems to have a life of its own.
    Sometimes it works, sometimes not. Sometimes will work (flash) after e-brake on for a while. Question-- what controls the warning lite and what do I need to change to fix it or to adjust it?
    Thanks for your help.
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: 61 E-brake warning lite
    Norm...
    A switch that has two tan wires attach to the hand brake assemble. one wire goes to the junction box. The other tan wire goes to the back of the speedometer and uses a special flasher bulb #257. The switch may be the problem, as many years of wear on the copper tab that rides on the hand brake ratchet has its effect.
