C3 Lug Wrench - NCRS Discussion Boards
C3 Lug Wrench
  • James Keddie
    C3 Lug Wrench
    I know that my jack is not correct but am not sure about my lug wrench. It has a paper tag attached (barely) that has 3898172 and GR8.821 on it. Anyone know the specifics on this wrench?
    Jim 42765
    Re: C3 Lug Wrench
    Jim -
    The presence of the tag indicates that it's a GM service replacement part; dunno if that part is the same as the original production part or not - someone more knowledgeable on C3's will respond.
      • 43241
      Re: C3 Lug Wrench
      Jim------
      The handle that you have is a SERVICE replacement part as John indicated. However, it's of the same part number as the PRODUCTION-installed part and it should be identical to the PRODUCTION-installed part. Remove the label and no one will know the difference.
      • James Keddie
        John & Joe - Thanks! *NM*
