58 Starter Solenoid - NCRS Discussion Boards
58 Starter Solenoid
  • Ken Susnjara
    58 Starter Solenoid
    In the process of wiring up my 58 project I was able to torque the starter solenoid enough to break it. Now I need to find another. First, is there anything special about the 58, dates, numbers, etc? Then, where is a good source for a replacement. I am trying to do a really accurate restoration. Any help or advise is appreaciated.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 58 Starter Solenoid
    Torque it where ? how? what broke?
    • Dennis A.
      • April 30, 1999
      • 1010
      Ken...
      Not sure how you broke it, you might try John Pirkle and discuss if he can restore it. (www.johnpirkle.com)
      • Ken Susnjara
        I tightened up the power electrical lead without using a back up wrench ( I know, dumb move) and broke the backelite cover into several pieces. You might be able to glue it back together but???.
        • Mark S.
          • July 31, 1983
          • 660
          You should be able to get a similar bakelite cover from a salvage yard. They are fairly easy to replace.
          • Mike E.
            • February 28, 1975
            • 5139
            Stamped into every original solenoid is a part number--I believe (going from memory here--a scary thing) that the 58 ended in 9919. (61-62 were 9910). If you don't have that, and you're wanting to do an accurate restoration, you'll need to find a correct one. If you want a visually accurate one, then the above posts are helpful, and are also helpful if it is the correct one and all you need to do is replace the original bakelite with a similar Delco one from the boneyard.
            • Ken Susnjara
              Thanks for the help.
              • William C.
                • May 31, 1975
                • 6037
                If you already have the stamped part number Mke referenced, the phenolic (Bakelite) part on the end that you broke is identical on all from '58-the mid-80's not only from Chevrolet, but almost any GM product, and as mentioned, very easy to replace. Turn around the terminals where the contacts are worn (obvious) and you are good to go...
                Bill Clupper #618
                • Roy B.
                  • February 1, 1975
                  • 7044
                  There are a couple on e-bay now
                  • Ken Susnjara
                    Thanks again. I glued the parts back together using epoxy and it works OK, looks OK too after a little work on the outside. I will probably take your advice and replace the back piece anyway, just to be safe. Again, thanks all.
