Block Casting Date Location - NCRS Discussion Boards
  • John Olcott # 33092
    I have found the casting number for my 1960 283 270hp block in the usual place (rear left side of block on top of bellhousing flange). Right now I am having trouble finding the casting date. Covin suggests that the casting date will be to the right of the casting number. What I see there is some sort of tag that is attached by two screws. There appears to be a raised character that is possibly and "L" or a "1". I don't think that this is the casting date as it is only one character. I cannot see any other digits, however, the tag is painted. Is there another location that the casting date may be? Covin suggests that there are. Any direction would be appreciated.
  • Ed Jennings
    Re: Block Casting Date Location
    It should be on the right hand side in sort of the same position that the casting # is on the left. I believe you may have to remove the road draft tube to see it.
    • Mark L.
      • January 1, 1996
      • 121
      John, Ed is spot on. Looking at the block from the rear the casting number is at about 10 o'clock and the date is at about 2 o'clock. I believe the "tag" you are refering to is what shift, 1st 2nd or 3rd, the casting was made.
        Thanks guys, I'll take another look.
