Timing cover/oil pan seal - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    (See link to picture below)
    Before pan gaskest is installed, there is clearance between the pan and the rubber seal in the bottom of the timing cover. So when the gasket is installed and pan bolted down there will be no deal. Am I missing something? Can the seal in the timing cover be "shimmed" with silicone to make it seal?
    Also, as an aside, what is the hole in the bottom of the block next to the fuel pump housing?
    Steve
    Daftar dan mainkan slot gacor dengan RTP tertinggi hari ini. VIPTOTO, situs terpercaya untuk cuan besar dari slot online!
  • Mark #28455
    Re: Timing cover/oil pan seal
    There are two thicknesses of oil pan front seals available. Are you using the thicker one?
    Mark
    • Steve D.
      • February 1, 2002
      • 990
      Mark
      I'm using the one that came in the set. It's right at 1/4" thick.
      Steve
        • 43231
        Steve-----
        The .22" thick front oil pan seal fits ORIGINAL 63-74 Corvette small block oil pans. If, per chance, you're using a later pan or a 63-74 GM REPLACEMENT Corvette oil pan, then you need the 0.41" thick front seal.
        If you're using a later pan and you ask for an oil pan gasket set for a 63-74 Corvette, you'll get the wrong front seal with it. All of the ohter 3 parts of the gasket kit are the same for all 63-79 Corvette engines.
        • Roy B.
          • February 1, 1975
          • 7044
          The hole near the fuel pump is to hold the pump push rod up using a long bolt to aid installing the pump. Then after the pump is installed use a 1/2 long bolt a brass washer to plug the hole or engine oil will blow out.
          • Steve D.
            • February 1, 2002
            • 990
            Roy
            The hole has a solid bottom; that is, it is not connected to any thing. (65 block)
            Steve
              Steve -
              The blind hole in the pan rail adjacent to the fuel pump is a master gage hole that was used to register the block on a locating dowel on the machining pallet; there's an identical second one adjacent to the starter bolt holes. Those two holes located the block when it was clamped to the pallet for its long trip through the block broach and machining transfer line.
