Silicone brake fluid detection. - NCRS Discussion Boards
  • Jerry
    A friend maintains a private collection of Corvettes and has noticed that several of the cars have crystal clear brake fluid while others have a more cloudy appearance, the clear ones could simply be the result of a well restored brake system while the others may be contaminated by impurities, (rust) Does anyone know of a method to determine if a car has silicone brake fluid or not. I attempted to search the archives with no success. Thank all for any assistance as always.
    jerry
  • Robert C.
    • December 1, 1993
    • 1153
    Re: Silicone brake fluid detection.
    Silicone fluid will not remove paint. Regular Dot 3 and 4 fluid will.Try a drop on a painted surface.(not the car's paint!)
    • jay
      I just changed my fluid to dot 5 and found the color different it was purple! I dont know if this applies to all silicone... does anyone else know?
      jay
      • Wayne W.
        • April 30, 1982
        • 3605
        Get a small paper cup. Draw a little fluid out of your MC. Mix some regular brake fluid with it. Let it set if it mixes and doesn`t separate you have regular fluid.
          • 15695
          Here's another trick. Conventioal glycol based fluid is miscible with water , silicone is not. The glycol based fluid absorbs moisture which slowly corrodes the iron in the system resulting in darkening of the fluid. Modern hydraulic systems beginning with aircraft control systems in World War II use mineral oil based hydraulic fluid with synthetic rubber seals. When hydraulic brakes first appeared on cars about 1920 the natural rubber based seals had no resistance to mineral oil so they had to come up with something else. Glycol was the best available material at the time, and we are left with this unfortunate legacy. Conventional brake fluid must be changed periodically to prevent corrosion from destroying the brake system from within. When guys first started having problems with Corvette disk brakes back in the '70s, it cost about as much to rebuilt the brakes as rebuild an engine. It's virtually impossible to change to silicone fluid by convention flushing techniques, so only change to silicone if you completely start from scratch with a new, dry system.
          • Jerry
            Thanks to all:
            What a great thread of responses, I appreciate the advice as always.
            jerry
            • Gary Schisler
              A little off of the topic, but regular brake fluid, DOT 3 or 4, will absorb moisture as a result of normal aging. It tends to turn the fluid pale tan or light brown. This can occur in just a few short months. Tell your friend not to worry about this. This is one of the reasons that I bleed my brake fluid yearly in my 66. It has stainless steel sleeved calipers but not silicone brake fluid.
              • Rob Brainard
                Jerry, Take Bob Cook's advice. It is the most simple and Sure way of knowing what you have.
                  • 43240
                  Jerry-----
                  There are many excellent responses here regarding means of differentiating silicone from glycol brake fluids. I've always used the one suggested by Wayne Womble; silicone is not miscible with water and glycol is. I put a little in a clear glass vial with water and shake. If it phase-seperates, it's silicone; if it mixes, its glycol.
                  By the way, silicone DOT 5 brake fluid is colored purple. However, the purple is a dye which rapidly degrades to a YELLOW color in service. So, you can't assume that if the fluid color is not purple then the fluid is not silicone.
                  • Jerry
                    EXCELLENT ANSWERS
                    As usual, thanks one and all.
                    jerry
