'66 SMALL BLOCK COOLANT LEVEL - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I drained SOME of the coolant out of the radiator to replace the thermostat. I put additional coolant back into the reservoir. Will that coolant make its' way back into the system, or do I need to add the amount I drained in a different way?
  • Kevin M.
    • November 1, 2000
    • 1271
    Re: '66 SMALL BLOCK COOLANT LEVEL
    Only way to add coolant is through the reservoir, when the thermostat opens it should drain out of the reservoir.
    Kevin
    • Rob A.
      • December 1, 1991
      • 2126
      Sounds good...thanks...
      • Chuck R.
        • April 30, 1999
        • 1434
        What I sually do is slowly add coolant back through the thermostat opening until it's just about flush with the intake flange. Then I re-install the new thermostat, gasket and neck.
        I always worry about that dreaded bubble of air that can get trapped in the block.
        I then top off the reservoir and fire it up. Then it's a matter of a small addition of fluid as the hoses and minor cavities will need to be purged as well.
        Chuck
        • Joe R.
          • March 1, 2002
          • 1356
          Hi Chuck:
          To avoid the "dreaded bubble of air" that you refer to, some people recommend drilling a small hole (about 1/8 inch) in the thermostat flange. This is enough to let air get past a closed thermostat, but not enough to defeat the thermostat function. I think the only side effect is a slight increase in the time it takes for the engine to reach operating temperature.
