C3 Rear Spring Washers - NCRS Discussion Boards
  • Gregory G.
    • July 31, 2001
    • 203
    Are there any decernable markings on the flat side of the washers that constitute originality or are they repro pieces?
    I had seen markings on these washers on some cars.
    Greg
    • 43240
    Re: C3 Rear Spring Washers
    Greg-----
    I'm assuming here that you're talking about the spring end cushion retainers (i.e. the large, FLAT pieces that look like washers). The current GM pieces which are of the same part number as the originals used for all 1963-79 Corvettes do have a very small stamping on the "flat" side which says "Made in Canada". I don't believe that the originals did have this. However, the stamping cannot be seen when the retainers are installed on the car and, as I mentioned, the configuration of the reatiners is otherwise exactly the same as the originals. So, for all practical purposes, the stamping is moot.
    • george romano
      Joe-
      I thought the side with the bevel went TOWARD the cushon. If so, can the stamping be seen when installed? Just guessing here.
      Pasta
      • Gregory G.
        • July 31, 2001
        • 203
        Yes it can be seen.Flat side down.
        Greg
          • 43240
          George-----
          Yes, you're right. The bottom ones could be seen. So, in that case, just grind it off (it's very lightly stamped and very small) or fill it with a little JB Weld.
