C1 headlamp sub body installation - NCRS Discussion Boards
  • Chris H.
    • April 30, 1990
    • 817
    I am cleaning up and reinstalling my headlamp sub-body assemblies. I see in the AIM a call out to use "3686683 (8.0 oz.) undercoating seal back of headlight and body panel around entire joint after assembly to prevent water leakage"
    How and when was this applied? It looks like the entire back of the sub-bodies were spray undercoated with just some overspray on the under body surrounding the sub-bodies. Which looks to me to mean that they were not sealed too well from water getting past the subbodies. The flat area on the subbody that sits against the outside body was not undercoated.
    Did they just do a poor job of undercoating or am I missing something?
    Thanks, Chris
  • Mike E.
    • February 28, 1975
    • 5136
    Re: C1 headlamp sub body installation
    You're not missing anyuthing, Chris--you're very accurately seeing the rather poor interpretation of those directions from intent into actuality.
    Something about a lick and a promise comes to mind.
    • Chris H.
      • April 30, 1990
      • 817
      Thanks Mike. Since I am not restoring the underbody yet I wll wash the underbody and pre spray the sub-body before installing. I will tape off the areas that would have been protected by the fender surface and spray sparingly around the outer edge. Should I use regular spray undercoating?
