63 water pump - NCRS Discussion Boards
63 water pump
  • Steve D.
    • February 1, 2002
    • 990
    63 water pump
    The attached picture shows the water pump that was on my early 63 NOM dconvertible (restoring as driver). It has no GM markings, and I assume it is aftermarket. I bought a rebuilt 3782608 which does not have the additional threaded outlet on top. I read a thread in the archives (Jan 05)on 63 water pumps and I believe that the additional outlet was referred to as a bypass. Can someone explain the bypass function to me ?
    Steve
    Daftar dan mainkan slot gacor dengan RTP tertinggi hari ini. VIPTOTO, situs terpercaya untuk cuan besar dari slot online!
  • NANCY CHARLES
    Re: 63 water pump
    THE BYPASS WAS USED ON SHP ENGINES SUCH AS 327/340 hp & 327/360 fuel inj. cars.going from the water pump to the intake manifold.
      • 15677
      Re: 63 water pump
      When the themostat is closed the water has to go somewhere from the pump or it will cavitate at relative low RPM.
      The bypass allows engine out coolant back into the pump inlet chamber where pumped back into the block. This prevents cavitation AND facilitates quick and even warm up.
      Corvette engines have up to three bypass circuits. The first is the "internal" bypass" - the third hole is the RH pump leg. Early SHP/FI engines have the "external bypass" from the inlet manifold to the top of the pump housilng, but this was eliminated on later SHP engines. The third bypass is the heater core circuit, but it would not exist on C-48 cars.
      Once the thermostat opens the bypass circuits are still open, but since the radiator circuit has much greater flow area, most of the coolant will flow to the radiator,
      Some engines have thermostat designs that simultaneously block off the bypass circuit(s) as the circuit to the radiator is opened.
      • James W.
        • December 1, 1990
        • 2657
        Re: 63 water pump
        Steve,
        You did not say what engine horsepower your '63 is equipped with. If it is a 250 or 300 hp then the 3782608 water pump without the bypass is the correct one. If it is a 340 or 360 FI then you would need a waterpump with the bypass. I know you said that the engine is NOM but does the intake manifold on your engine have provisions for the bypass hose to the water pump? If it does not, then you don't need the water pump with the bypass. You can buy a remanufactured GM 3782608 water pump from NAPA for around $18.00 with core charge. I recently purchased one of these for my '64 327/300 hp Corvette as a spare to take with me only the NCRS Road Tour this summer.
        Best Regards,
        James West
        Omaha, NE.
        • Steve D.
          • February 1, 2002
          • 990
          Re: 63 water pump
          How do pumps with no bypass avoid cavitation?
          Steve
            • 15677
            Re: 63 water pump
            As far as I know,all SB pumps/blocks have the internal bypass, so even if the engine has no external bypass and C-48, there is still the internal bypass.
            • Steve D.
              • February 1, 2002
              • 990
              Trying not to be thick, but
              what is the C-48 reference?
              Steve
              • Steve D.
                • February 1, 2002
                • 990
                Re: 63 water pump
                James
                The engine is the 340 HP (L76), and the manifold is set up to accept the bypass connection..
                Steve
                • Donald L.
                  • September 30, 1998
                  • 461
                  C48= Heater & Defroster Delete *NM*
