C-1 '62 Clutch - NCRS Discussion Boards
C-1 '62 Clutch
  • Donald B.
    • May 31, 2004
    • 299
    C-1 '62 Clutch
    I have a 327 250 hp. I need to replace my clutch assembly - the disc is fairly worn so now is the time. I want to maintain the original "touch" or foot pressure.
    I see that Corvette Central has an assembly (pressure plate, disc, etc.) any experience if this is the "proper" replacement?
    Also, any other sources to obtain this assembly - maybe locally (So. Ca)?
    Re: C-1 '62 Clutch
    Pretty thorough prior threads in the archieves on the topic of replacment clutch assy's including recommendations from several on what they like in terms of 'off-the-shelf' brands available from your local discount autoparts store...
    Last, not mentioned is possibility of having the old clutch you've grown used to rebuilt with a fresh Kevlar face. Figure that'll be about half price what you'll pay for an all new clutch assy...
    Some have had bad experience with locally rebuilt cluch assy's, but a fella who does this in our neck of the woods has an excellent reputation for his work, so it 'can' be done right...
