Aluminun Rad/Heads Steel Block - Antifreeze - NCRS Discussion Boards
  • Dennis B.
    • May 31, 2004
    • 175
    A combination fo Aluminum radiator, aluminum heads and a steel block. What antifreeze requirements are needed to combat corrosion. Reccommended brands?
  • Jim T.
    • March 1, 1993
    • 5351
    Re: Aluminun Rad/Heads Steel Block - Antifreeze
    There are several posts in the archives you can view by Duke Williams on antifreeze. GM factory installed in the later model C4's the Texaco Havoline DEX-COOL extended life antifreeze in the aluminum radiator, aluminum head, and cast iron blocks.
