67 - 390hp Distributor Advance Curve - NCRS Discussion Boards
  • Douglas L.
    • August 31, 2003
    • 299
    Anyone have information as to the optimum distributor advance curve for a 67 - 427 - 390hp? Motor has never been rebuilt.
  • William C.
    • May 31, 1975
    • 6037
    Re: 67 - 390hp Distributor Advance Curve
    Factory spec for a 1111247 '67 dist is 0@900, 8.5 at 1250, 17 at 2000, and 32 @ 5000, all crank degrees and crank speed. Vac advance is 0@7 inches vacuum, 12 @ 12 inches per the '67 service manual. That would be a good place to start with today's fuel.
    Bill Clupper #618
    • Douglas L.
      • August 31, 2003
      • 299
      Bill,
      Thanks for the info.
      • William C.
        • May 31, 1975
        • 6037
        If you decide to purchase a reproduction vacuum can, make sure to test it. I had one on my machine this week with a brand new reproduction can and the vacuum point where it started to operate was off by 50% (too high) Not the thing that will give you the "driving experience" you would like.
        Bill Clupper #618
