C-2 Differential detailing - NCRS Discussion Boards
  • Kurt K.
    • June 30, 2004
    • 194
    I just had my 67 diff blasted and would like to detail it the correct colors. I am using Cast Blast (a driver) for the housing. What colors were the side yokes and drive shaft flange? Thanks, Kurt
  • Joe C.
    • August 31, 1999
    • 4598
    Re: C-2 Differential detailing
    Kurt:
    Since these are cast parts, paint with cast blast. The deflector shields are unplated steel, so use a clearcoat on them.
    The true factory finish is uncoated on all these parts. Some have had good luck with periodic application of a silicone based protectant like "Pre Lube 6" to all uncoated chassis parts.
