Pinion Companion flange Remover Tool (J-8614) - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    I want to install new pinion bearings on my late '65 differential. Where do I find the Kent Moore tool described in the title ? It's the long wrench that bolts to 2 of the 4 the yoke U-bolt holes to hold the yoke while you tighten or loosen the pinion nut. Do members have any experience in fabricating a substitute tool ? Are they available from tool rental shops ? Do auto specialty stores sell them (I think they would be used for all Chev vehicles) ? I'll be driving stateside (Montana, Idaho, Oregon) in a week, and would like to obtain if available.
    (side-note) My diff. has one of those intermediate pinion designs, with 30-splines for the yoke, yet with the short crush sleeve [0.625" virgin; approx. 0.560" crushed] that seats on a step of the pinion shaft (rather than the long sleeve that goes from inner bearing race to the outer bearing race); just like the '63-64 design that has 14(?) yoke splines. Any estimate of the torque that will be required to crush the virgin sleeve ? (to achieve the pinion bearing pre-load of 15-25 inch.lbs for new bearings).
    Sorry, Roy B. -- no 3-second blast on an air gun (I'm not THAT lucky).
    • 43238
    Re: Pinion Companion flange Remover Tool (J-8614)
    Wayne-----
    Tool J-8614 is still available from SPX/Kent-Moore. I don't know if anyone else makes a similar tool or if these can be rented. This is a tool which is NOT specific to Corvette. It is used for a wide array of GM models, right up to present models, I think. That's probably why it's still available.
    One word of caution, though: the prices of Kent-Moore tools have increased ASTRONOMICALLY in the last 5 years, or so. You may be stunned when you hear the price. You can call them at 800-468-6657. They're usually very helpful. Their web-site is useless, though.
    • Mike McKown
      Any reason you can't use a long handled pipe wrench? I don't have the manual handy but I think it is around 250#. Just a guess.
