1967 Wheel Trim Rings mounted to the wheel rim two different ways according to Noland Adams in his Restoration Guide. The first design was a 4 clip design which is very easy to indentify. The second style was a friction clip design. How can this design be identified as authentic?
Tags: None
- Top
Re: 1967 Wheel Trim Rings
Doug -
The original '67 trim rings had the four separate clips that gripped the edge of the rim flange; the other retention scheme with friction fingers all the way around are found on service replacements and reproductions.- Top
Doug - For what it's worth, two of my original beauty trim rings were stolen in Sept. '67.
The over-the-counter GM replacements at that time had the grippers the entire circumference of the trim ring, and not the four 'clips' style (which was standard with the car.)
Tom- Top
