I can't get my water pump gaskets to stop leaking. After I jack the motor up and get the bolts started real good, my logic was to let it down so the weight is where it will be and then tighten. Should I tighten all the bolts and then let it take the weight or should it matter. My last attempt has the water streaming out the top left bolt hole.
LP
LP
