66, 427, 3869942, Block?? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 939
    I need a "942' block for a dec. 66 vette. Are they hard to find, where they used in passenger cars? Are pass. and vettes the same? Too many questions, anyone have answers? Thanks.
  • Mike M.
    • May 31, 1974
    • 8383
    Re: 66, 427, 3869942, Block??
    the two bolt main 942 isn't too rare but few full size chevys came with the 425 hp 4 bolt main 942. go to carlisle in august, ad in driveline, hemmings etc.don't forget to get a block built a month or so PRIOR to the vette's build date. good luck. mike
    • John L.
      • 409
      Hi Bill -- didnt you mean a December 65 942 block ???? Have you tried Engines Limited in Wisconsin.
        Same casting was used in different passenger car & truck applications. What makes a 'Corvette' engine is the suffix code(s) wacked on the stamp pad designating the basic block was internally and externally configured for Corvette.
        On availability, well any casting that's now 40 years old is going to be harder to come by than a newer engine. But, they're out there!
        • William B.
          • April 30, 1975
          • 939
          Thanks, John, I need a block for a 66 vette built 12/21/65. I guess any block before that date, what was typical 4 to 6 weeks before? Thanks again to everyone for the help.
          • John L.
            • 409
            Bill -- amazingly, my 66 427/427 coupe was built approx 12/17/65.
            • William B.
              • April 30, 1975
              • 939
              Well John, I guess you have an engine I could use. No just kidding. Also you have the very desirable 425hp, mine is a 390hp. I wish ncrs kept a data base of engines that people may offer for sale. Maybe we could reunite a lot of engines to cars?
              • Jon #40768
                It would be a time consuming task, but worth it to the few owners that could find there blocks. I have a 66 vette 427 block with the correct corvette stamped pad, but I need a 67 vette 427 block. I would be happy with a correct block even if it was not THE original block.
                Jon
                • George W.
                  • May 31, 2000
                  • 544
                  Jon, what date 351 block do you need? I have a late may 4 bolt. G.
                  • Jon #40768
                    Re: 67 351 Block
                    George. I am greatful for your consideration. Unfortunitly, I need an October 1966 or eariler block. I have a 1966 block and an early 1968 block, plus the 1966 block in the car.
                    Thank you again for the thought. I hope the guy that was griping about the corvette hobby reads about your kindness.
                    Jon
                    • George W.
                      • May 31, 2000
                      • 544
                      Re: 67 351 Block
                      Jon, what is the date of your early '68 block? I am looking for a 3916321 2 or 4 bolt with a very early date (before early September of 1967). Does anyone know the first date of production for the '68 year models? Thanks, g.
                      • Jon #40768
                        Re: 67 351 Block
                        I am leaving for work. I will get back to you.
                        Jon
                        Hit me again if you dont hear from me
