Often, I find used big block forged crankshafts that have been turned
.010/.010 -or- .020/.020 -or- even .030/.030 and the question I have is over
their actual stability in a SHP engine. I am referring to the '7115 crankshaft
in particular, as the '6223's are a dime-a-dozen these days. In any event, can
any of you share your experience(s) in building an SHP engine ( L-88 or similar
performance ) using one of these "turned" cranks? What I actually would like
to know is, does the use of a crank with reduced journal diameters ( mains &
rods ) promote bearing failure faster than normal due to the increase in the
bearing wall thickness?
Having asked that, what would be an acceptable undersize crankshaft to limit
myself to? Getting a '7115 crankshaft that would be deteremental to the life
of a restored engine seems foolish, doesn't it.
Steve
Steve
