' 65 AFB Carb mounting / 300hp - NCRS Discussion Boards
  • Zachary K.
    • March 1, 1986
    • 162
    I'm trying to figure out the corret layers of gaskets, before mounting this carb to the manifold. Are there just three pieces or should there be one more gasket. The order I think it should go is intake manifold / gasket / black spacer / metal spacer / carb. Is this correct or should there be another gasket between the metal spacer and the carb making it four pieces? I have checked all available sources of reference for this and can't seem to find anything. I have checked the Assembly Manual / Judging Manual (old edition) / Nolan Adams Book / Shop Manual / various aftermarket catalogues..........
    Thanks for the help!!
    1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
    1969 L71 LeMans Blue, Bright Blue Convertible
    1970 L46 Monza Red, Light Saddle Convertible - Duntov
    1976 L82 Classic White, Firethorn
    2013 LS7 Black, Ebony, Convertible
    Moved on -
    2006 LS2 Black, Ebony, Convertible
    Re: ' 65 AFB Carb mounting / 300hp
    Zachary -
    The "sandwich" is correct as you've described it - intake, gasket, insulator, baffle, carb.
      • 15680
      The '63 AIM clearly shows the parts and assembly sequence, and so should your '65 AIM, but you have to look in the RPO L-75 section since it was an optional engine.
      The main sections of the AIM show the "base" configuration. Option configurations exploded drawings are in the RPO section at the back in alphanumeric order.
