Source for '66 headlight wiring harness clips - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7020
    Does anyone know of a source for the two clips that hold the headlight wiring harness to the underside of the metal reinforcement just in front of the front edge of the hood? The clips have a split barbed point that inserts into a hole in the reinforcement bar and the other end is about 2" long x 1/4" wide x 1/8" thick and the two ends of this side are aligned with the axis of the harness tape and gets wrapped up into the tape. Hard to explain in words. I can't find these two clips in either the Paragon or Long Island Corvette catalogs. Does anyone make a repro?
    Gary
  • Dave K.
    • November 1, 1999
    • 952
    Re: Source for '66 headlight wiring harness clips
    Gary,
    I'd try Lectric Limited. They make the replacement harnesses - other wise if you found an old repaced harness grab them off of the old harness.
    Dave Kitch
    33108
    • Scott Marzahl
      If I understand what you are looking for correctly, the wire clamps that fasten to the header bar are listed in Long Island, sec 4, item 46. I just received some.
      • Gary B.
        • February 1, 1997
        • 7020
        Scott: I think we're talking about different ones
        Scott,
        Correct me if I'm wrong, but I think the ones you're talking about are the outboard ones that the harness slips into. There are 4 of these, 2 on the left and 2 on the right. These are metal and the part of the clip that the harness slips into are black rubber coated. The 2 clips I'm talking about are inboard of the outer pairs that you're talking about and the ones I'l taking about are all plastic and light gray. I can try and take a photo tonight.
        Gary
        • Scott Marzahl
          Yes, different clips.
          Yes, I just received the 4 metal clips. I guess I'm not yet aware of the 2 plastic ones you are looking, but I think I will soon be looking for them too...just when I thought I had all the little parts ready to go:)
          • Gary B.
            • February 1, 1997
            • 7020
            Scott: I'll send you a photo tomorrow *NM*
            • William C.
              • May 31, 1975
              • 6037
              Re: Scott: I think we're talking about different o
              The clips were GM part number 2977427, mnaufactured inhouse by the former Packard Electric Division, now the Packard Electric Systems group of Delphi Automotive. They used to route small orders via a distributor, Pioneer-Packard at 1-800 Packard, but that was four or five years ago.
              Bill Clupper #618
              • Gary B.
                • February 1, 1997
                • 7020
                Thanks Bill; I'll give them a call. *NM*
                • William C.
                  • May 31, 1975
                  • 6037
                  Re: Thanks Bill; I'll give them a call.
                  Might also check the standard parts catalog at your local Chevy Dealer, or look at where they heep small supplies for the body shop.
                  Bill Clupper #618
                  • Gary B.
                    • February 1, 1997
                    • 7020
                    Looks like those clips are GM discontinued
                    Bill,
                    A quick check on gmpartsdirect.com indicates that those clips are discontinued.
                    Gary
                    • Gary B.
                      • February 1, 1997
                      • 7020
                      Bill, where do you find that GM part #? *NM*
                      • Chuck S.
                        • April 1, 1992
                        • 4668
                        Re: Looks like those clips are GM discontinued
                        Gary, early C3s have the same type harness clip in the radiator support area.
                        I tried looking specifically for that clip on other GM cars of the same vintage in junkyards without much success. I was able to find harnessess with that type clip, but if the clips weren't already broken, it was likely I would break them in removal just as I broke the originals. I believe I was finally successful in getting two that I needed. The years and exposure to UV light make recovering junkyard specimen of this clip difficult at best.
                        Years ago, I ran across a small electrical vendor at either Bloomington or Carlise that was selling a clip that was similar, but not identical. I think the vendor name was "Eagle Electrical" or something like that. I don't know if he's still in business, or sells the clip now that many of those old parts are discontinued. As I recall, it was clear or white, and shaped a little differently on the harness flange. If painted flat black and wrapped into the harness, it would be nearly undetectable once the harness was installed. You might keep an eye out for him...maybe someone else knows who I'm talking about.
                        • Page C.
                          • February 1, 1979
                          • 802
                          Hi Chuck,
                          I have got a business card from Eagle Wire Products at the Knoxville Expo last fall.
                          Don Martin
                          3308 Valley Forge Dr.
                          Knoxville, Tn 37920
                          1-800-977-0030 /865-609-0010
                          DonMartin@comcast.net
                          He had alots of neat clips and wiring harness type parts.
                          Hope this helps,
                          Page Campbell
                          • Chuck S.
                            • April 1, 1992
                            • 4668
                            Page, I believe that's the guy...thanks. Gary should check him out.
                            • Gary B.
                              • February 1, 1997
                              • 7020
                              Page, Chuck; I'll send him an e-mail; Thanks *NM*
