C1 Oil Gauge problem - NCRS Discussion Boards
  • Mark Malone
    Hi Guys,
    A buddies oil gauge in his 62 is reading full pressure (all the way to the right) when running but returns to zero when switched off.
    I haven't done any work on a C-1 oil gauge so I'm not sure where to start.
    Any help will be much appreciated.
    Thanks, Mark.
    My Vette Page
  • Mike E.
    • February 28, 1975
    • 5138
    Re: C1 Oil Gauge problem
    Not sure there is anything wrong--if high volume/high pressure pump is installed on the engine, it could very well peg the gauge except after a long drive when oil is hot and thinned--at idle it might come down. My experience is that the gauge is not the problem--it's simply reflecting something going on in the motor.
    • Larry P.
      • June 30, 1999
      • 481
      Mark,
      I have the high pressure oil pump and it does exactly that. After it gets hot it goes to about 50lbs on low RPMs.
      LP
      • Dave Suesz
        My 55 has run
        like that since I was a small child, both the original engine and the all-correct 55 replacement, 40-50 at idle, pegged out when driving.
        • Roy B.
          • February 1, 1975
          • 7044
          Re: My 55 has run Dave
          {pegged out when driving} = Your going to blow a valve cover some day!!
          • Rob M.
            NCRS IT Developer
            • January 1, 2004
            • 12758
            Roy,
            Why are you expecting this result because of high oil pressure. I would expect all part just be better lubricated?
            I'm always eager to learn something each day...
            greetings,
            Rob.
            Rob.
            NCRS Software Developer
            • Dave Suesz
              Well, in fifty years and 122,000 miles
              it hasn't yet, probably because I have the correct road draft tube installed, insuring no positive pressure can exist in the valve covers or anywhere else.
              • Dave Suesz
                Theoretically yes, but very high pressure
                can also indicate blocked oil passages, which means something isn't getting oil at all.
                • Roy B.
                  • February 1, 1975
                  • 7044
                  Rob! it was a joke!!!!!!!!!! You cant blow a valve cover off HA!
